MTR 3000 Mix mode and firmware
ktkadude
Twister Chaser
Great Bend KS
I recently obtained a MTR3000 that needs to be setup for Mixed mode and from the looks of it that option from Motorola is not possible to purchase any dealers out there to sell a Dynamic Mixed Mode EID for an MTR3000 HKVN4044. also the firmware is at R01.06.22 and I can not seem to upgrade it using the CPS 16.0 with the supplied firmware availible from Motorola wich starts at 2.10
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Time to bite the bullet and get CPS 2.0 to update to newer firmware.
Firebuff880
Boynton Beach, FL
Looks Like you have multiple problems here --
R01.06.22 is Vintage 2009. You probably need to get that repeater to R01.12.17 before it can jump to R02.anything. But since I have not done a jump this big in a long long long time, I am not positive about that.
Any Firmware in the R01 family, and R02.09 or older needs a version of CPS (n-16) to install/update configurations. R02.10 and newer must have the second-generation CPS 2.0. I think CPS 6 was the Version with R01.06.
If the firmware is that old, then the repeater has not been PMed in a long time and you may have any number of dried CAPs and other issues that the power supply in that unit. The MTR-3000 is famous for power supply failures as they age.
RadioGuy7268
PA
You will not be able to activate the EID in CPS 16 even if you were able to source a Mixed Mode EID. EID license activation with the older CPS 16 and below is no longer an option with Motorola.
As mentioned above - you're going to need to work in CPS2 in order to upgrade firmware, and R 2.10.x is as high as you can go without buying a SUM License.
