Mtr2000
fireguy810
Have a mtr2000 for a Uhf repeater. Looking to hook an external speaker to it to place in the truck bay. Where do I connect on this unit?
There is a "service speaker" connection on the front, under the cover. It's the RJ-11 type connector on the left side, next to the BNC external reference connector.
I think the output is pretty low, I think you need to use the amplified speaker to get useable audio out of it.
From the MTR-2000 installation guide:
Service Speaker:
connects between the telephone connector on the Station Control
Module and an external speaker/amplifier (with a 6 pin molex connector)
via an adaptor cable; part number 0185180U01.
GmanX
The speaker volume is adjustable by the software.
cmdrwill
So Cali
MTR2000 does not have a speaker or speaker output.
It does have a low level line out on the 6 pin connector. That has to be externally amplified to drive a speaker .
GmanX
What am I thinking of then. Isn't there a slider for the volume. I've left the darn thing I carrier squelch a million times from the software. I have only used the test speaker. Maybe that's it. It's not the standard Motorola speaker.
hitechRadio
There is a special Speaker HSN1000 via adapter cable 0185180U01 and to adjust volume and or turn PL on off you need, GMN6147b microphone with the 3 buttons side buttons. These options are for techs to trouble shoot and test the station, and not typically used the way I think you are describing to be used.
I really think a tone remote setup would be a better solution for you, if station is equipped with tone remote board. This way you could put remotes in different locations through out the station, and also have transmit capabilities.
Another option is to by a public address PA, radioshack sells them and run speakers throughout.
ramal121
Lots and lots of watts
Calif Whine Country
If you are looking to run a MTR2000 locally, say as a base station, that can be done. Any 8 pin Motorola mic can be plugged into the mic jack and work. Doesn't have to be the specific test mic (although the side buttons do help). As far as receive, the only thing lacking is an audio amp to drive a speaker directly. You'll need the amplified speaker and interface cable as hitechRadio mentioned above. In the RSS you have complete control over the speaker volume and can switch RX PL on off or just blow open squelch if that is your bent.
If you just want to remote a speaker out to another location, (tens of feet I imagine), you'll have to roll your own extension cable (six pin phone style straight through) male to female to get the speaker to where you want it.
