Anyone else have any problems running MTrunker32 under Win2k? I recently replaced my Celeron 333 Win98 box that I was using to run DOS versions of Trunker and ETrunker (along with MTrunker under Windows) with a Celeron 533/256mb. Things started off just great... I copied over my MTrunker32 folders and data and away it went. It likely ran about 2 weeks before I came home to find a window saying 'Mtrunker32.exe has generated errors blah blah an error log has been created blah blah'. No big deal, I just restarted MTrunker and away it went. But now, it seems to be getting worse. Sometimes it will only run minutes before crashing...other times hours. Doesn't seem to be any rhyme or reason to it. The PC is dedicated to Trunker... nothing else is running, so it shouldn't be a hardware issue. I am also getting 100% decode rate on the system that I'm monitoring, so signal strength isn't an issue. The only thing running in the background is PC-Cilling Internet Security, which I have just disabled to see if it may be the culprit. I guess I'm just looking to see if anyone else has had an problems with Win2k and may have any pointers or tips to help me out.
Many thanks!
Many thanks!
