MTS 2000 Belt Clip Broke
TheWarlock
Mississauga Ontario
Hey,
Yesterday I had the Belt Clip part snapped off the battery and broke the plastic that holds the belt clip. what are my options.
R
retiredmich
Guest
Do you have all the parts? if so get some ( J&B weld) it comes in a packet of 2 tubes @ walmart & con be use on plastic. follow directions & put your belt clip back together.
cmjonesinc
Depending on the brand of battery you may be able to take the shell off and glue another one on it. I had some junk batteries laying around and was bored and did it once. I noticed the name brand ones are hard to open but the cheapo ones will crack. If you have an interstate battery salesman near you a new battery may be cheaper than you think. The one for my firehouse hooked me up with an interstate brand battery for less than the cheap ones on ebay.
TheWarlock
Mississauga Ontario
They are right down the road from me. Ill take a drive down to them and see what they can do. Thanks
Sticky topic
Not real familiar with that radio, so I don't know if my suggestion interferes with charging
But if it's a good battery, I'd just superglue a clip to the battery.
Buying a second clip to use with other batteries you may have is going to be much cheaper than buying another battery.
Me personally I'd go this route before I did surgery on a good battery.
fdscan
New York
Not sure if I would suggest using superglue or JB Weld.
If the superglue/JB Weld lets go while you have the radio clipped to your belt or pocket or whatever, the whole radio falls to the ground which could obviously do some damage.
motocomm
Cincinnati, OH
I have portaclips available, feel free to message me if interested. cheaper than 24 bucks, fyi. Can post to my ebay if preferred.
