MTS 2000 using QUIC CALL II
W4JLR
Lavonia, GA
I am trying to find in the Windows base CPS where I can use Quic Call II for my MTS 2000. I read the radio and when I goto the drop down menus to select quic call II it is not available, I mean you can see it but It is faded out, you cannot click on it and select it. any suggestions?
ducommff
The answer to your problem is your radio is not flashed for that option. The MTS 2000 is a flashport radio witch means the radio is only capable of doing the options that are flashed into the radio from motorola or the dealer. The only way you can do QC-II is if you go to the motorola dealer and buy the flash option for QC-II and then they will flash it into your radio and then you can use QC-II on your radio.
