If you mean FAIL 01/93 yes your radio is bricked.
FAIL 01/82 is an external checksum error, check your RIB and cabling and, try writing the radio with the last saved codeplug FROM that radio in normal RSS.
If the firmware is greater then 5.41 DO NOT USE LAB RSS ON IT.
If you have a radio of the same model, type and flashcode, you can try to use normal RSS to clone the radio, if you don't have a saved codeplug from that radio. Do NOT confuse toolproof (FAIL 01/93) and external checksum error (FAIL 01/82) as the same thing.
