MTS2000 Programming help
jtisdale656
Summerville, SC
Hi, Can a Motorola MTS2000 (H01UCF6PW1BN) be programmed on a 800MHz SmartZone Trunking System to receive only? I have Motorola CPS software for MTS radios. I am kinda new to Motorola programming and only really messed with Kenwood programming so any help would be appreciated.
TheWarlock
Mississauga Ontario
What is the flash code
jtisdale656
Summerville, SC
ok thank you. I've been trying to just set it up in general but I keep getting a error on the talk groups. I add a talk group and it turns red and won't accept it in the radio trunking configuration.
jtisdale656
Summerville, SC
I've had no problems setting the conventional frequencies and trunking control channels but the talk groups is always coming in red as a error.... (if that helps). I've seen 1,000 videos about programming conventional just nothing about programming trunking.
I can't say for sure, but my guess is that is related to the lack of a system key. To program trunking systems, you need a key that allows you to do this; even if it's for monitoring purposes only.
jtisdale656
Summerville, SC
I set up the system key through DOSBox. Everything is programming correctly except any talk group I try to add. It's on SmartZone type 2 throughout the entire configuration.
N4KVE- I'm not sure how to set it as Smart Net. I don't see a setting change for that from SmartZone.
jtisdale656
Summerville, SC
As long as it shows the #1 under talk group in the talk group section of the Trunking Personality 1 of 1. Once you add a talk group it turns red and shows "Trunking Personality Talkgroup in Trunking Personality-1, member 1"
