MTS2000 Software still available?
Nasby
Ohio
Anyone know if the software for the MTS2000 can still be obtained from Motorola or have they stopped support of that model? I don't want to go thru the hassle of setting up an account only to find its no longer available.
Thx in advance,
bezking
On the Road
Yes it is.
Item number RVN4176 is for JUST the MTS2000, price is $279.
Item number RVN4177 is for MTS2000 AND MCS2000, price is $417.
clanusb
Northern CA
what programming cable would you recommend to use?
an ebay $20 cable or a motorola cable with the rib-box?
bezking
On the Road
I have a kawamall ribless serial cable (from eBay) for the Pro series - it works fine, but an original Moto will work beyond question.
bezking
On the Road
Direct from Moto you would need the cable and a RIB (Radio Interface Box - sits between the PC and radio, ribless cables have the components of the RIB built into them)
- RIB - RLN4008: $200
- Cable - RKN4035: $227.85 (<-- I'm not 100% sure this is the right one, you might want to call motorola and ask)
- You would also need a DB9 to DB25 cable to connect the RIB to the PC, you can get these real cheap online or from a store like Micro Center
Total: $427.85 + $279 for CPS = $706.85 (Insane, right?)
I have heard also that the RIBs from PolarisUSA.com work well.
RodStrong
Polaris cables are good. Much better quality (more durable) than the KawaMall types. KawaMall and Valley Enterprises cables should work fine, but if you don't want to pay Mothership prices but want something that can take a beating, I would recommend Polaris. Wiscomm cables are in between KawaMall and Polaris durability-wise in my opinion.
Good luck.
bezking
On the Road
No - Polaris also sells a RIB at less than half the cost - you would need the Polaris RIB and a cable.
clanusb
Northern CA
what is the number of the cable for PC to rib?
ive selected the PA1 and the model 14-NV from polaris
Nasby
Ohio
I can live with the $279.00. Would I be able to simply buy a ribless cable with a serial connector from ebay and use that to program the radio or is a ribless cable and box, etc. a must?
Devilz311
NJ
I've used a Ribless serial cable, with a serial to USB cable with no problems at all with any of my MTS2000's. I've since switched to a home-built RIB box that I bought from a member here. It has the standard cable connection for Motorola rib to radio cables, as well as an RJ-45 (ethernet style) plug that I can use for the CDM radios.
