MTS2000 Tx fine but receives only noise
silodk
Kolding, Denmark, Europe
Hi all you good guys,
I have 5 MTS2000 VHF radios. Before I tried to program them, they worked fine. The problem was that I did not have the license to operate them on those channels.
So now I have programmed one frequency in.
I have cloned all of them.
Now when I turn them on I only hear noise. Like the squelch is not closed.
That was not a problem before.
When I transmit the other radios also is not receiving the signal. But if I listen on a scanner its all fine.
Something is gone wrong with the receiving part of all radios.
I have now tried to put in the old original codeplug. I saved a backup in the beginning.
I still cant receive.
Is it possible to brick the radios receiver just by changing the codeplug? I have only deleted the old freq, put in my own and all other settings are the same as before?
Thanks!
Br. Simon
