MTS2000 UHF High Split
N7AS
Prescott Valley, AZ
Can a MTS2000 High Split "S" 450-520 be programmed to 70cm ham (440-450)?
I have CPS R.02.03.00
If so, how well does it work?
radioman2001
New York North Carolina and all points in between
It's going to be pot luck, some will others won't, you will get Fail 001 if display model, and a constant low tone. I have a "R" split that won't do the transmit "T" band freqs but receives them fine. Once you get the VCO to lock again it's pot luck as to how sensitive it is. Transmit is usually not a problem
