mts2ooo fail code 01\81
said73us
Egypt
Hi everybody
I have many radios mts2000 model2 and model3 show error code 01\81 on radios display , i determine the fault is the ATML EEPROM 256k on the controller board , i have replaced it with another working one from another mts2000 radio . the damaged radio becomes working very good but i can't program with CPS . i bought a new blank ATML EEPROM and mounted it on the control board but, i need to know how to program the new blank EEPROM on mts2000 's controller board
i use CPS already to program mts2000 , i can't use it only when change EEPROM with a new blank one or changed EEPROM from programmed working mts2000 radio ..
thank you very much
MTS2000des
256K controllers are not compatible with CPS, nor do they support Flash upgrades.
only 512K controllers with F/W higher than 5.62 are compatible with MTS2000 CPS.
you'll have to use DOS MTSX RSS and a real DOS computer to read/write 256K MTS2000 radios.
said73us
Egypt
i use CPS already to program mts2000 , i can't use it only when change EEPROM with a new blank one .
thank you
