There seems to be a misconception that Motorola won't sell you their software. This is FALSE.
I don't even have a business, yet I am able to get just about anything I want from Motorola. As long as you are willing to sign their RSS licensing agreement and pay the $$$, you should be able to get the software.
You cannot get the RSS for certain radios that are dealer-channel product (mainly the newer Waris series stuff) but you should be able to get the MTSX RSS (that covers your MTX8000).
The easiest way to do this is go to
http://businessonline.motorola.com/ and apply for a MOL account. Once you do that, call MOL support and ask them to add "software support" to your account. This will allow you to download and sign the RSS agreement. From there, they should add the RSS software to your account. If they don't, open a case and get them to do it.
From there you should be able to order RVN4176N, which is the MTSX RSS. This has the latest DOS RSS and Windows CPS for the MTSX radios (MTS2000, MT2000, MTX8/9000)
I had a runaround getting them to add the RSS to my catalog, but once I talked to the right person it happened very fast.
If you use the wrong version of RSS on the Jedi radios, you can toolproof them, and the only way to get that fixed is to send them back to Motorola and the minimum bench charge there is $350.
batlabs.com is a good resource for the M stuff as is the batboard.batlabs.com.
Rule #1 there is don't ask anyone for RSS. If you do, you'll get banninated.
Any other question you might have about M stuff (and some other commercial stuff) someone there will have an answer.
It's not a good idea to be asking for RSS any other place either--- M is very protective of their software. Once you license it, it is yours and yours only, you cannot resell it or transfer the rights to anyone else.
Also, it is NOT a good idea to be programming trunking radios onto a system where you are not authorized. People have done *serious JAIL time* for that! If you do, you'll probably get your radio inhibited by the system, and good luck getting that undone.
If you want to listen to a trunking system, get a scanner. Yeah, they suck audio-wise compared to genuine Big M gear, but at least it's legal and you won't get your radio turned into a brick.
All that being said, once you get your M stuff programmed the way you want it, the Motorola sickness will set in, and you won't want to use anything else.
Good luck,
-b-
