MTX-1550
PMan976
Dawson Creek , BC
I have 2 MTX-1550 VHF Trunking Radios. They are both fairly new and they both have the same issue, which I find Odd as they have basically sat on a shelf for the majority of their life.
Both radios power up with no display. The menu does not come up , nor the channel info .. Zip, Nada.
I find it hard to believe both displays went at the same time .
Has anyone else come across this on these radios.
Thank You
KevinC
Big Dog...celebrating 10 years of abuse!
Home
Sounds like they both have been inhibited.
rescue161
KE4FHH
Hubert, NC
You can read the radios with CPS and it should tell you if they have been inhibited. If they were, then you have to talk to the system admin that inhibited them and have them un-inhibit the radios.
KevinC
Home
Wow! 2 1/2 years later. :p
PMan976
Dawson Creek , BC
These were new radios we had on the shelf, Nobody should have done that to them, but it may have been done by mistake when our tech was programming it. I believe that he just downloaded another profile.
rescue161
KE4FHH
Hubert, NC
Inhibiting is not done via programing. It is done via Site Lens for trunking or via a console for conventional. Are you saying that the they are fixed now? If so, then they were more than likely not inhibited.
PMan976
Dawson Creek , BC
I doubt that is the problem then. I just appears that both radios lost the display at the same time. I was wondering if anyone knew of a Display option or something in the settings that would have turned them off. I looked and couldn't see anything out of the ordinary.
I will note these are not set up as trunking radios.
rescue161
KE4FHH
Hubert, NC
Yep, MDC inhibited via console. Are the radios working? Have you tried to read the radios with CPS?
