MTX8000 Delete TRS
James04TJ
I have a couple MTX8000s from a now defunct type I system. I typically program VHF and UHF conventional systems in RSS and 800 systems in CPS so I am not too familiar with using the MTX RSS with trunked personalities.
Is there a way to delete the last trunked system in the MTX8000? These radios will be dedicated to NPSPAC conventional interoperability channels. Even though I can setup the Zone/Channel configuration to not point to the TRS at all I would prefer to remove the system from the codeplug all together.
RKG
Boston, MA
The easiest way to delete a "system" for which you do not have a SysKey is to change the SysID to that of a system for which you do have a SysKey, after which you can delete it.
James04TJ
Thanks guys. I was able to delete everything except for the last system. Since the system is defunct anyway I just removed it from being mapped to any zones or modes. So it is still in the codeplug but just not accessible.
If you want that specific system out of the radio, you can create a new system and a new personality referring to that system, and then delete the old system and personality you want gone. But no, a trunking-capable radio can't have all of its trunking info removed.. it has to have at least one system and one personality present.
