Mtx9250
Mtx9250
Hello,
I have an MTX9250 that I want to get the TPT tone on and I'm not sure how to do that
Echo4Thirty
The only way to get that is to program it onto a trunking system. The conventional tricks that are present on the XTS series are not on the MTX. You could conceivably use PRE-MDC1200 signaling, but then you would be squawking a data packet at the beginning of each TX
Mtx9250
You don't say...
There's more than one. Which one are you talking about? The MDC TPT or the Trunking TPT?
Trunking TPT
Stupid question on my part but, is that bad?
K2NEC
Depends what you want to do with it.
Try this for the best results:
DTMF system, Primary ID:000 PTT ID Type: Pre Only, PTT Sidetone checked, Pretime(ms):0, TX Duration(ms):25. Interval(ms):25
Closest you are going to get to a trunking TPT on that radio.
Echo4Thirty
Trunking TPT
Sending the MDC1200 data burst (or DTMF codes) over the air might annoy people (at best) or in the case of sending zeros, activate features on the repeater controller. Zeros are used from time to time on amateur repeaters. Yours may or may not. I was just pointing out that others will have to listen over the air to whatever method you choose.
IFRIED91
Arrive alive
NYC/Westchester/around the area
Mitsubishi still makes those haha?
But trust me owning a bunch of commercial radios including an APX which has amazing audio and is even delightful to listen to on analog in places like nyc, MDC1200 which is muted to a blip gets annoying and tiring very fast
