Muffled Digital Voice Quality
DiGiTaLD
You have 800 MHz XPR subscribers? These NPSPAC MA are 800 MHz.
Mine are UHF (403-512). "NPSPAC" may not be the correct term for the national UHF mutual aid channels UCALL40 through UTAC43 that are listed in NIFOG.
RFI-EMI-GUY
NPSTC
did the more recent allocation and naming conventions for all the public safety mutual aid channels (primarily VHF/UHF) while NPSPAC specifically did the much earlier planning of the 800 MHz mutual aid public safety channels as well as the operational PS channels.
Motorola has apparently blocked those 800 MHz MA channels in the MotoTrbo products. There are some technical issues, with the narrower NPSPAC channel mask, but to my knowledge that did not apply to the five mutual aid channels out of consideration that they were for mutual aid and not every agency used channels in the NPSPAC block. This may have changed post 800 MHz re-banding,
salarazad
Any suggestions about the Environment profile? is it worth enabling and which profile is most recommended?
Thanks!
redrock2002
Default is best especially if you have an earpiece. Loud amplifies the received audio but if the radio volume is high already it really distorts. The loud setting helps in a high noise environment.
