ProScan: Multi-edit
midnightsteel
Stafford Va
How do I change similar properties of multiple frequencies in a group at the same time? For example, in FreeScan I could set the alert color for multiple frequencies in a group at the same time by "shift clicking" multiple frequencies and changing the property drop down box. It would then change the property in all selected frequencies
ka3aaa
middletown, pa.
Edit one cell with the new information that you want, highlight the edited cell, use the fill down option to change the rest of the cells below the corrected one if my memory is correct. I think.
midnightsteel
Stafford Va
Fill down option? I dont remember seeing this. Where is this option?
ProScan
Ontario, Calif.
1. Edit 1 cell with new info.
2. Select the cell that you edited in step 1 then select any cells below the 1st one that you want to change.
3. Right Click anywhere over the column and choose the type of action.
"Select" means using the Windows keyboard and mouse way of selecting.
