Declared_Hostile
Hopefully this is the correct section for this.
Would there be a problem with using one of the outputs of a Stridsberg Engineering active 8 port VHF/UHF multicoupler to feed the antenna input of another identical multicoupler?
If there is no problem in using one of those outputs to run another multicoupler there should be no problem in using two of the outputs to do the same thing correct?
