Multicoupler and fm trap
Bonkk083
Union, SC
If I add a fm trap filter will the multicoupler make up the loss
dlwtrunked
The loss of a good FM trap should be near negligible outside a certain intended range. Gain in a multicoupler counters to some extent the FM trap. You cannot really consider one without the other and the specifications of each. But in my experience, a GOOD FM trap (like the Mini-circuits and yes, good is not cheap) first is what one should start with and go from there. In general, you will not go wrong doing that.
Ubbe
Stockholm, Sweden
FM traps should only have some 1-2dB loss outside of the broadcast band and a Stridsberg have a 3dB gain or more. But a Stidsberg isn't really a low noise device, having something like a 3dB noise figure and are bit too sensitive to loose sensitivity when exposed to high signal levels. If you lowest reception in a receiver are -120dBm then a Stridsberg will change that to -117dBm and a filters 2dB connected before the Stridsberg will change that to -115dBm.
A better solution would be an antenna amplifier with less than 1dB noise figure that will compensate for all devices noise figures, even a receivers relative high noise figure as scanners always have bandpass filters before any amplification that could have some 3-4dB loss. It would then change that -120dBm value to lower than a -122dBm sensitivity and you then can use a passive splitter instead of a expensive multicoupler. (-122dBm=0.18uV -120dBm=0.22uV -115dBm=0.4uV)
/Ubbe
Bonkk083
Union, SC
/Ubbe
Will it be better without the Stridesburg that has more noise for weak signals I noticed more static
Ubbe
Stockholm, Sweden
If you only use one of its outputs then reception will be better without the Stridsberg. You use it to compensate for splitter loss when you have 2 or more receivers connected to the same antenna.
/Ubbe
