Multicoupler QuestionS
dimab
CT
1. What is the difference between active and passive couplers?
I saw a price difference of 200% for active vs. passive from STRIDSBERG
2. Can a STRIDSBERG multicoupler handle transmission from a ham to the antenna?
3. Is there a multicoupler that will enable me to share a single TX antenna that will do RX functions and TX functions? (specifically the Austion Spectra, which is what i have for scanning right now, and is able to TX)
Any links to products and explanations why or why not's are greatly appreciated.
wa8vzq
Minnesota
1. An active multicoupler has an amplifier that makes up for the loss associated with distributing the received siganl between serveral receivers. For the sake of argument and neglecting other losses, a passive 2 port multicoupler splits a single antenna into two receiver ports. The signal level at each port is 3 dB lower than the signal at the antenna. An amplified multicoupler would have 3 dB gain so that the signal level at each port equals the signal level at the antenna.
2. Multicouplers are one-way devices designed and are not intended to handle transmitted signals.
3. Not to my knowledge - when you begin adding transmitters into the mess, the situation becomes very complex. Multiple transmitters can share a single antenna using diplexing techniques - usually cavity filters and at some frequencies also using feritte circulators. Each cavity and circulator is adjusted for a specific frequency. They can be configured to transmit and receive BUT only on the one frequency. This essentially how a repeater operates. A single transmitter and a single receiver are diplexed together to share the same antenna.
Dan
Apple Valley, MN
