Multicouplers
R0am3r
Salt Water Conch
Oneida County, NY
I use the Electroline EDA2800 as a multicoupler for my scanner activities. I have another model (UDA-UG-2402) for my TV antenna distribution system. These models use F-connectors. Check ebay as a source for these units, but make sure it includes the power supply
nessnet
What month is it?
Short answer: yes.
Especially those made for the frequencies most people would be monitoring.
Long answer:
"Multicoupler" can be different things to different people.
For instance, there was mention of an "F connector", which in my book would actually be a TV splitter, not an actual multicoupler. And..... splitters have RF loss. A standard 2-way splitter has about 3.5 dB to 4 dB loss per port, while a 4-way has about 7 dB, and an 8-way can cause up to 14 dB of signal loss. 3.5 dB to over 14 dB is not good if you are in a weak signal area.
A TRUE multicoupler is an active device and does not have any loss - maybe even a slight gain. I'm sure I'll have disagreement on this, ("waste of money", "just as good", bla, bla, bla...) but it is the same as most things - you get what you pay for.
For instance:
Stridsberg Multicouplers
Chris0516
Pittsboro, North Carolina
If you buy an off the shelf unit you can usually specify connector type! Build one and use what you need! I have BNC and N connector models!
Ok
I think I have one of these: SP-1300 Combiner/Splitter | Scanner Master I just need to see, if I still have it.
Ok
Short answer: yes.
Long answer:
For instance:
I went to Stridesbrg page, which prompted my question.
  • Like
Reactions: wtp
