Multiple Antennas
SkandicSwt
Timmins, ON Canada
Hello everyone I'm new to the scanner world and just purchased my first scanner which is a Whistler TRX-2 and my question is: Can I run more then one antenna with a splitter to the TRX-2? I want to know because I'de like to have more antennas that can have different applications and wondering if it would be possible to cross frequencies and would it create a scrambled issue or would the best antenna for the frequency pick it up and broadcast it with no trouble or interference from the other antennas?
Swipesy
Northern Ohio
I am using a Comet CF-413 Duplexer for the 1.3-460Mhz and 840-1400 Mhz bands. You can transmit and receive with the unit. It does not require power so you can run it mobile. It has seperate leads for 2 antennas in and one output. About $50.00. You can buy them tuned for different frequencies.
