OP25 Multiple Counties Sharing Same Frequencies
krutzy
Culpeper, VA
I have two counties in my area that I am interested in. There are two sets of frequencies in RR each county, however they seem to share a lot of them between each other. This is based on logging with a P25RX I have. There seems to be some P25P1 traffic included but that isn't the problem.
One county has a NAC 00A and the other has a NAC 00F. I have seen the same frequency used as the CC for both at the same time. Sometimes there are two different CC used. I can see in the new release of OP25 where traffic is in one time slot for one county and at the same time the other county using the other time slot.
What I am asking is how would I set this up in the op25 trunk.tsv since each has a different NAC but they each use the same frequencies and CC's? I am not sure how the software would handle this.
Kevin
boatbod
Talbot Co, MD
Kevin
For a start, since you know the NAC value you can specify it in trunk.tsv (or cfg.json) and that will make op25 ignore the other traffic.
