Multiple Discone Attic Antenna’s
TwIzTuD
EDGERTON
If I install multiple discone antennas in my attic will they interfere with one another?
They will be the exact same model of antenna (Whistler WMM-860 Multi Band w/Discone) just feeding different directions. Is it an issue if they are within 4 feet of each other?
Not lots of room in my attic so I gotta get shorter units unfortunately.
Thanks for any help
If they are really close, you can end up making a very slight directional pattern, but 4 feet should be plenty for receiving only.
Have you considered using one antenna and just adding an amplified distribution amplifier? Might be a cheaper solution, and a bit of amplification may help performance.
TwIzTuD
EDGERTON
Thanks,
One is my sons and he wants to take it when he moves out or your suggestion would have worked
