Multiple Receiver Audio Recording
N_ALSCAN
Huntsville, AL
I've been searching for an easy way to record multiple receivers.
Several times, I've been at work/asleep/ or simply not had a scanner on, and a major event has occurred. I would like to be able to go back and listen to the recorded audio.
Of course, I could simply run several instances of a scanner audio recording program. But, where is the coolness in that? I would like to record audio directly to a computer, for easier playback and searching.
I've had difficulty in finding a multiple input recording device that had VOX capability.
I think I may have finally found an affordable solution.
digital-loggers.com lists 2 possibilities, both connect to the computer with a USB connection.
The first unit is called Radio Logger, and has 8 XLR inputs, and is priced at $595
http://digital-loggers.com/radlog.html
The second unit is an 8 input telephone logger, with RJ-11 connectors, and is priced at only $395
http://digital-loggers.com/dli.MIL8000U.html
Does anyone on this board have any experience withe digital-loggers equipment?
The $395 price on the telephone logger is very attractive. However, would I need any special filters or transformers to drop the audio down to the proper levels? Or, would I just be better off going with the XLR input unit?
I will probably leave the audio source radios on a single frequency, each. Therefore I plan on using Motorola Maxtracs, as they are more compact (and probably cheaper) than using scanners for my audio sources.
Does anyone know of a better solution, than any of the above?
Thanks,
Rob
KC0QNB
Gothenburg, NE
You can get a multi channel sound card for $150, then use a 1-7 channel recorder software like this I use a couple of their products no problems so far. wouldn't hurt to use a "direct box" like of course the cost is still around $400 but is a complete system.
N_ALSCAN
Huntsville, AL
Thanks for the link to NCH software, I had not seen that company or software before.
I especially like the remote control and remote listen software.
It is really tempting, since the software is currently on sale at about 50% off normal price until July 15th.
I would like to hear from anyone who is using this software, to see which soundcards work best.
I am thinking that I will use the M-Audio Delta 1010LT soundcard, as that appears to be the card that they are selling for their software.
Thanks again, and I will be downloading the trial this holiday weekend to check it out....
Rob
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
As listed in our recording software wiki, several of the Signal Intelligence products such as Trunkstar Pro mention they can record from multiple inputs. Something else to consider - although I'm not a fan at all of their habit of making their audio files unplayable in standard windows players.
73 Mike
