I wonder if any of these issues improved when they updated the P2 firmware!
No I have the latest firmware and I am having the same issues! It sounds terrible
A few clarifications:
1) It has nothing whatsoever to do with multipath interference from simulcast cells
2) It has nothing whatsoever to do with "interference" or "bleed over"
3) The updated 1.04.03 firmware made no difference whatsoever
4) This issue has only been reported with TDMA talkgroups; so far it does not appear to affect FDMA talkgroups
5) We are experiencing this issue with a 700 MHz system, whereby the scanner is attempting to tune to invalid frequencies in the 78x MHz range for TDMA voice frequencies. Those frequencies have nothing to do with 800 MHz rebanding.
6) The fact that it's trying to tune to frequencies that high in the 700 MHz band indicate that it's not calculating the correct TDMA voice frequencies with any degree of consistency.
There are at least two of us in this thread who have technical knowledge and firsthand experience with these ASTRO 25 TDMA systems far beyond that of the average hobbyist. I do not say that to come across as arrogant, it's simply a fact that is important to understand before taking stabs in the dark at offering up possible causes or solutions. Rest assured that if we say there is a bug with the scanner processing the TDMA band plan, then the problem is real.![]()
For me, the 3 P25 Phase 2 capable systems that have issues are the correct bandplan on the 996P2. That was checked against a BCD436HP that picks up Phase 2 constantly and a GRE PSR 800 that has stellar response times on Phase 2 transmissions.
Could the cause be a co-located cell phone? From what I saw on the Youtube video isn't that or close to a cell phone frequency it is stopping on?
Well, if that's the cause someone needs to contact the FCC as the radio would be in violation of the ECPA of 1986. :wink:
The lack of acknowledgement from Uniden that an issue exists is just ridiculous.
It isn't like it's difficult to reproduce, heck they can even do it from their office.
And it's not like we are doing anything wrong, we scan JUST a P2 system and it works, we scan the same P2 system and ANYTHING else and it acts up.
Not looking for an immediate fix, just a "We can reproduce the issue and are investigating".
I suspect the first acknowledgment you'll see is a new firmware release....
I just checked the Table of Allocations for the frequency 866.3625 MHz.
That frequency is a previous NPSPAC frequency - the band that moved to 851-854 MHz due to rebanding. If a TRS is sending a scanner there, I would check the trunking tables the system is broadcasting.
Here is another thought. Do you have another scanner located in the same room? Are their antennas close? I have seen the interaction between scanners here at my home. The scanners were a BC786D and a BCD996T. When the BC786D stop on a frequency and the 996T would stop on a transmission at the same time I would receive intermod on the 996T.
I haven't done any tests with my 2 BCD536HPs but I think that I am seeing the same problem on them.
