Multiple voice receivers with Unitrunker (possible feature request)
mdodd
Montclair, NJ
I know it is possible to have multiple voice receivers with Unitrunker but I am looking to assign each voice receiver to a certain system (or maybe group of systems).
I've searched around and experimented a bit but cannot seem to find a way. Is this currently possible?
If not, as a feature request, I think simply adding a priority field to a voice receiver would easily do the trick. If it wasn't too much trouble having something like Site Lock but for a system would be awesome for a voice receiver.
Open to any suggestions, let me know what you think!
bbrasmussen
Woods Cross, UT
I know it's a feature that's been requested. Until it's implemented, a workaround I found is to run a separate instance of Unitrunker for each different site you want to monitor. It obviously takes a lot more system resources, but it works.
The crowd wanting this are mostly hosting streams. They want different listening criteria for each stream. It's under consideration. Beyond Brandon's suggestion, but there's no easy work-around at this time.
