No worry! I'm at the range of the repeater 100% as I am on the building!
I try to use my ham radio with the Motorola systen where I work as we don't enough if that info can help!
Understand FCC Type acceptance if you are in the USA. Amateur radio gear is not necessary legal to use on Part 90.
Just more info to help you guys to help me!
I am able to recieve the channels 1 to 4 on mutiples frequencies with each of one a different group as follow...
Channel#1 456.7000 CC11 TG110 TS*
Channel#2 456.7000 CC11 TG120 TS*
Channel#3 456.7000 CC11 TG130 TS*
Channel#4 456.7000 CC11 TG140 TS*
TS* = seems to change automaticly!?!?
So, when you says "channels", are you referring to the channel settings on the work radio, as in the knob on top?
From what you are showing, that would be a single channel trunk system, in very generalized terms.
Same frequency
Same color code
Talk Groups are sort of a virtual channel they can share multiple groups of users on the same system and they won't hear each other.
Time Slots will change depending on what's available for use or what has been programmed. The system looks for a free timeslot and uses that.
I can transmit 20% on the time on 456.7000 with CC and TG but 100%!
When I recieve a call I'm 50% able to reply if I push the PTT quickly as if they are a "window time"..
This is a major red flag to me.
Answer this question honestly, with no B.S.:
Do you have written permission from the owner of that radio system to access/transmit on it?
This will be a "yes" or "no" answer.
If you do not have written permission to use that system, STOP. You are actively violating many FCC rules.
Amateur radio operators, hobbyists, employees, or anyone else does not get a blanket free pass to access any radio system they feel like.
If you do have permission, have the system administrator either issue you a properly programmed radio, or ask their radio tech for help programming your radio to access their system, if and only if:
The radio has FCC Part 90 certification
The radio has not been modified
The person who's name is on the actual FCC license has said it is OK and given you written permission.
There are precisely ZERO variables here.
You either have permission or you do not have permission. There is no waiver for hobbyists. FCC rules are real. Trying to hack into someone else's radio system can get you in trouble. Even if you have permission, it sounds to us like you do not have the experience or technical understanding to be programming your own radio to access this system. There are very specific FCC rules that address this sort of situation, and it really sounds like you are in violation of those.
I try to add or minus 5.000khz for 461.7000 or 451.7000 and nothing happen on the 461.700, so it's inccorect but on the 451.7000 when I try to transmit all radio's DEL light turn on and flash in red!
Any idea?
Yeah, you really need to stop what you are doing.
Get your amateur radio license and use your amateur radio on amateur radio frequencies where it belongs.
