MultiSpecW32
scanfan03
Houston, Texas
Does anyone know about the weather sattelites on 137.62 and 137.5?
I want to decode them, I have MultiSpecW32 and I was wondering, do I need to have it hooked up to my scanner's discriminator output? Can I just hook the cable up to the headphone jack?
Does anyone know of any other free weather sattelite decoding software?
Joseph11
For pretty much any data decoding from your scanner, you'll need to use the discriminator output.
Voyager
Aren't those frequencies typically AM? If so, you will need to tap the detector, not the discriminator. The discriminator tap only applies to FM signals.
Joe M.
scanfan03
Houston, Texas
Joe M.
I am pretty sure that these are FM.
jwood
Beverly Hills, Florida
How to Receive Weather Pictures from NOAA Satellites
So you have decided you want to receive the NOAA and Russian METEOR orbiters and you have a radio that receives 137.500 MHz and a computer. So now what do you do? I hope this short dissertation will steer you in the correct direction.
To display a picture from the orbiting birds you need several things. First you need to 'acquire' the satellite. This means you need the program to calculate its position at any time and determine if you can hear the signals from the 'bird'. The best place to get this program is probably AMSAT-NA an organization dedicated to AMateur SATellites. They have several very good tracking programs for the IBM and also for Commodore and Apple as well. After you have acquired the program and have it running on your computer, you then need the Keplerian Elements for the NOAA satellites. These elements as well as some tracking programs are available from the CELESTIAL RCP/M, run by TS Kelso, at 513-427-0674 (Fairborn,OH) and from the Weather Fax and Remote Imaging DATALINK BBS run by Dr. Jeff Wallach, N5ITU as bulletins for some 100+ sets of satellite data. Another bulletin also tells you to what the printed numbers correspond so you can enter them into the computer program. Use the newest elements you can find as the orbiting satellites are subject to forces which change their orbits. If you use Keplerian Elements more than 3 or 4 weeks old, your chances of hearing the bird are reduced.
Once you are tracking the birds you should hear them on your receiver. They will be on 137.62(NOAA-9/11), 137.500(NOAA-10), and on 137.850, 137.400, and 137.300 for Soviet Meteorlogical Satellites / METEOR. Now comes the first thing different about NOAA orbiters. The frequency deviation of the FM transmission is about +/-18-20 kHz. This is 4 times the normal deviation of a police call and 1/3 the deviation of the FM broadcast band FM signal. If you receive the signal on the regular communications width of the scanner the light areas of the picture will be noisy and the signal will sound distorted and the picture will basically be useless. If you use the FM broadcast bandwidth (assuming your scanner will let you), the signal will be weak and there may be too much background noise to see the picture.
So what now ? Well there are two ways to fix the problem, find a receiver with the proper I.F. bandwidth filter of 50 kHz, or modify the I.F. of your scanner to about 50-80 kHz. The simplest mod which has been found to be workable is to remove the narrow communications I.F. filter and replace it with a 0.01 uFd capacitor. This provides for good Wefax pictures from GOES and pretty fair NOAA orbiter pictures. It can of course result in retuning the radio, voiding the warranty and making the squelch not work properly.
The other characteristic of the NOAA satellite transmissions is THEY ARE WEAK. To get good pictures over a large area we have found a pre-amplifier to be essential. A GaAs-FET type can be obtained from various sources at a reasonable price but still about 50-100 dollars. You can also build one for about 25 dollars from plans for a pre-amp for the 2-meter amateur band and tune it to 137.5 easily.
Lastly, but importantly, the antenna can be of an omni directional, uniform pattern type such as a turnstile antenna similar to those used in the FM broadcast reception business but of course tuned to 137.5 MHz. Mount the pre-amp at the antenna if possible. Crooked coathangers on broomsticks have been known to work, and it is not difficult to build the antenna. Of course 2-meter beams with Az/El tracking will do the job well.
Now that you have a nice audio signal from the satellite, what happens next? The audio tone of 2400 HZ which is the carrier tone that is used to carry the picture information (video), must be detected and the video data converted from analog to digital and then displayed on the computer monitor by the software. The hardware and software to do this is available from several sources with more coming along. Several stand-alone boxes are also available that produce some form of computer output either in printed form or on the display. In addition the people on the DATALINK BBS may also have some data to share with you regarding this equipment.
One of the best sources for information is the WEATHER SATELLITE HANDBOOK by Dr. Ralph Taggart. The 4th edition will be available from the ARRL later this year. A must is THE JOURNAL OF THE ENVIRONMENTAL SALELLITE AMATEUR USERS' GROUP - JESAUG - which is published quarterly. It is available for $30.00 per year from the editor, Jeff Wallach, PO Box 117088 Carrollton, TX. 75011-7088. Back issues of the JESAUG are also available.
One good place to start is with the Elmer Schweittek MULTIFAX software which runs on the IBM PC. A hardware kit is available from A&A Engineering which includes the video dectector circuit and A/D converter. Input to the PC is via the game port. If you want to build your own, complete documentation to build an interface circuit on an IBM PC prototyping board is available from H. Paul Shuch, N6TX, for $6.00 - FAXBOARD is also described in QEX, Sep `88.
The units available from Jim MacLean, Ralph Taggart, and Jerry Dahl listed under Sources are all well worth investigating if you are just getting started. DATALINK will have available by early summer an APT interface card for the IBM PC that can be built for less than $100.
RagnarD
In a valley that only a few know where it is
Hi There,
Based on the frequencies you have listed I think you are referring to the Polar Orbiting Satellites (Low Earth Orbit).
Catching these things is pretty easy. I am not familiar with the interface you are using but back about 7 years ago we built interfaces for about 10.00 each and built antennas as well for about another 10 bucks out of PVC pipe and some RG-8 Coax.
This inteface plugs into the audio output jack of your scanner and then ties to a serial interface on the PC. No need for a discriminator tap.
If you want I can look around and see if I still have any of the information on the interfaces and what application we used to copy them.
It was exciting at first but after you hear the "ping ping ping" come from over the horizon and it gets stronger the closer it passes over head and then weaker as it gets on past you it seems like it was a lot of work for an image you can get from the Internet :?
Hope this helps
73
de
chris
kq4z
scanfan03
Houston, Texas
Yup, those are it!
I am just using a 1/8" to 1/8" mono to mono cable. Plugging it into the mic input on my computer.
OK so no discriminator tap, go it.
That's ok, you don't have to. If I can't do this for free (excluding scanner) than I am not going to get into it.
Well, usually the internet is about 30 minutes off. This is current up to date. Also, who else can say that they can get live weather information (except obviously like meteorologists and people who work at NOAA). I guess it is just cool to be able to say that you get live weather feeds at curtain times of the day. :twisted:
