i have a bcd996t using arc996 and i cant even get muncie on it...ive fried several trunking types...i haev no clue to what their trunk ids are...has anyone been able to get muncie police and how did u do it???
Muncie Police are on SAFE-T. I also have a 996 and pick them up fine.
How do you have them programmed? Would you be willing to let us see your file so we can possibly see where the problem is?
I’m not familiar with the ARC software I use Uiden’s on a 396 so I’m not sure how much this will help. The system type is Motorola 800 Type 2 standard. Use these frequencies for control channels 866.2250, 868.2625 and 8687.750. When scanning use ID search instead of ID scan. Unless there are major differences between the 996 and 396(and my memory is here) this should get you started. At least making sure you scanner works.
See Scanner Frequencies: Indiana Project Hoosier SAFE-T Trunking System, Statewide, Multi-State for talkgroup info. From what I understand on a 996 you need to set the type of talk groups analog, digital or both. Most of Muncie/Delaware County are analog. The 32xxx to 33xxx are analog the 38xxx are digital. Most of the digital are not being used or are low use right now. About a third of the analog are not in use or low use. I’d program all of them you never can tell when someone may pop up on them. I hope this makes sense.
i couldnt find the id's anywhere then i ended up putting it on scan ids instead of search id....now im pullin them in like crazy and writing down ids to hopefully associate with services...thanks for the help guys. it would have been eaiser if they had that listed in the manual as a troubleshoot topic but oh well....if and when i get these ids sorted...ill be sure to post them so no one else has to struggle like i did
thanks again...Joe
thanks again...Joe
