MURS Frequencies
C138NC
Tactical Taco Consumer
NC Taco Command
I dont know if this is the right place to ask but MURS are non license right?
but if im getting one programmed to operate on MURS Freq's, is the TX/RX the same? such as 151.6700 is the tx and then rx would be the same or something else?
rescuecomm
Travelers Rest, SC
The transmit and receive freqs are the same. No repeaters are allowed. The radios are limited to 2 watts.
Freqs are:
151.8200 narrowband
151.8800 narrowband
151.9400 narrowband
154.5700 wide or narrowband
154.6000 wide or narrowband
The last two are heavily used in urban areas by drivethrough fast food restaurants, etc.
Bob
C138NC
NC Taco Command
thats what i thought but i placed DPL's on all of my MURS frequencies so i think im good :D
rescuecomm
Travelers Rest, SC
That is what we did with our hunt camp radios. The MURS VHF radios have much better coverage than the UHF GMRS radio gear and we were using public safety type WT's.
Bob
C138NC
NC Taco Command
I have 2 GP300s but im looking into buying more to use for my post but they are all going to stay with me :D I dont feel like seeing.. "my money" walking off and then getting lost...
but im glad :D we have MURS and i would be programming that into my next set of radios
C138NC
NC Taco Command
Also to add, if i have the MURS on my radio, am i allowed to place DPL codes on them? but anyone with CSQ will hear me right?
C138NC
NC Taco Command
What? do increase range? I think you cant exceed over 20ft or 60ft? i forgot but mmm
iMONITOR
Silent Key
S.E. Michigan
The FCC puts no restrictions on the amount of gain that a MURS antenna may have. The only restrictions are the antenna cannot be higher than 60 feet from the ground if free-standing or 20 feet higher than the structure it is mounted on.
C138NC
NC Taco Command
Mmm maybe i can suck up to my emergency management coordinator to let me borrow some space :)
wkredick
Waterford,New York,USA
Is it legal to program 2 watt MURS into a unit capable of 4 or 5 watts? I thought I heard it was not somewheres.
Just curious.If not illegal,then I am all good.
C138NC
NC Taco Command
I lowered my output just to be safe :D, i tested it out with one of my advisors and i made it atleast... 14 blocks from where he was and i was somewhat a quarter mile away though i know the max range is usually 3
N
N_Jay
Guest
I believe the units have to be specifically type accepted for MURS service to be legal.
C
cqcqcq
Guest
MURS is great, I use a 7 element beam at 35 feet, and can talk to a friend at 20 miles with no problem...I talked to a distant station one time at 50 plus miles<believe it was skip>., but havent heard that station since, but they were using a beam also.
CQCQCQ
C138NC
NC Taco Command
CQCQCQ
Thats sweet but is that allowed?
W2NJS
Washington DC
If you want your MURS questions, all of them, answered in one place, just do a Google search. There are several sites that all have this information, both in Q&A and FAQ forms.
C138NC
NC Taco Command
Well one of my GP's are programmed with MURS while the other stays for my other county
Scottsbluff, NE 69361
as for legality on using non certified radios if you turn your power down to 2 Watts and stick to the 154 mhz MURS frequencies I don't think you would be harassed for using part 90 radios.
there are so few certified MURS radios in circulation that you have no choice but to use part 90 radios.
ianal though.
personally i see no reason for type certification requirement for MURS or GMRS when there are plenty of part 90 radios that meet the requirements for either service and so few radios specifically certified for part 95 MURS or GMRS.
But that is your tax dollars hard at work for you. not.
