MURS vs GMRS Cedar Point
bosco836
I have previously used Uniden GMRS radios at Cedar Point with limited success in regards to range. Has anyone used MURS there? If so - how well can I expect my MURS portables to work there?
bosco836
So, what type of range can I expect with MURS relative to the 2W GMRS portables that I was using previously? More? Less? Equal?
KD8DVR
Columbus, Ohio
While GMRS has a *50* watt max legal power, the bubble pack cheapies have anywhere from 300 mW to about 3W output. Nautrally, you require a license for GMRS. GMRS and FRS frequencies are crowded, with lkots of interference. I use 900 Mhz FHSS radios now, which work well. You should expect better performance from MURS, as most of the stuff out there is commercial grade.
lmrtek
The major problem with MURs is the interference from much more powerful licensed users that can easily wipe out your communications.
A good set of gmrs radios should give the best range vs reliability since they are now available in 5 watt versions.
The Tri-Square radios have very poor range in comparison and frequently loose sync between units requiring you to find the other unit and move closer to re-sync.
I have all 3 types and I found that my scrambled gmrs radios are the best
dnoyeb
Southfield, Michigan
Last amusement park I visited was using MURS for their operations. So you might find some channels occupied. Of course this was not Cedar Point.
