muting trailing tones on end of edacs communications
xnaron
Does anyone know of any hardware or software that is capable of muting the annoying tones on the end of analog edacs transmissions?
thanks
gmclam
Fair Oaks, CA
EDACS
Typically those beeps occur because you do not have the system your are monitoring programmed correctly/completely. What scanner are you using? What system are you monitoring? (A link to that system here on RR would be nice). Have you programmed all of the "repeaters"?
xnaron
I am using SDR with unitrunker. Not a traditional scanner setup :)
xnaron
I figured out a way to mute the tones using sdrsharp. Set the Filter bandwidth to 8000. Check mark "Filter Audio". I am using Blackman-Harris 4 with 400 for filter order. I also use the digital noise reduction plugin set to -96db. Good bye annoying trailing data tones! I'm sure you lose some voice quality for me it was only slight.
motomeso
Ontario
Now that Unitrunker has native RTL support we need to find a new way to mute the Edacs Beeps.
W8RMH
Feed Provider Since 2012
I do know that every Uniden scanner made since the BCT15 mutes them.
I am still running Etrunker .. and am looking for the same thing. But I want a programmatic solution. I have the source code .. but I am only a so so C programmer. I need someone that really understands it ... to help me.
But til then .. then I will keep searching.
Anyone ?
