markanderson
do I need put all the Mutual Aid talkgroup in my scanner
I just started monitoring the MA TGs. They are a lot busier than I thought!Mark, if your referring to the SAFE-T, yes, program all 10 SWMA's in, and the regional MA's for your area. They are used frequently for many reasons. On the District MA's you can hear BOLO's, and dangerous conditions put out by local PD's, and SO's so anyone in the area can be aware of things, as well as calls for aid. I consider Mutual aid freqs/TG's to be essential in any scan list.
ISP can interop with local agencies on either the MA's, or switch to the agencies TG's. And in most areas where an agency has its own system, they usually have the capability to switch to that system as well. This is daily here in Indy.
I may be wrong but I would think you will still have some analog MA channels/talkgroups. Partly because NFPA requires the on scene communications to be analog for firefighting. Or they used to or that may have been changed.Just remember, all that changes over the next year. Motorola is upgrading the SAFE-T to ASTRO-25 P25 Phase 1. Bye bye analog, hello pure digital.
