MWV13222HDS Maxrad/PCTEL Gain NMO Antenna Question
evfd1625
Indiana
I have a PCTEL MWV13222HDS which is supposed to be a wideband 1/2 wave gain VHF antenna with NMO mount, however when I received the antenna it has a whip that is 49 inches long, it does have the spring, the base shows 132-174mhz, the cutting directions with it say for 148-174 MHz the antenna should be cut to 28 1/4" with the spring and 31 1/4" without the spring. I left the whip at 49" and placed it directly on the base. When I had the spring on it seems way too long, but the inches given in the cutting chart do not seem accurate. Does anyone have a correct cutting chart for this model with the spring and without, centered at 155 MHz?
kayn1n32008
ØÆSØ
Sector 001
Cut it to 28 1/4".
174-148=26/2=13+148=161.
I know the math looks ugly but With this measurement it will be centred around 161MHz. While a bit high, being a 1/2wave it will make little difference. At the band edges it will be @2.0:1 or less.
I use a Sinclab 1/2wave for my LMR radio and have no issues from 144-174MHz.
Sent from my iPad using Tapatalk
cmdrwill
So Cali
29 1/4 inches with the spring.
NOTE: Cut the rod from the top, that gives you the full diameter rod and the ball at the top just gets caught in the garage door anyway....
