MX Connector (KVL)
cs361
Libby, MT
I am looking for the socket MX connector that would be similar to the MX300, but that sits in a KVL. I am making a custom cable, and I need a socket (female).
I have searched everywhere I can think of to find one, but no luck. Any ideas? Or am I searching the wrong thing?
I'm looking to turn a MX connector to Hirose, without cables and need it to be female. I want to use my existing KVL cables on a different key loader that doesn't use the MX connector, and don't really want to butcher my current ones, or buy more.
I know I can get Motorola Hirose keyload adapters, but I'm also loading Harris XL200P and XL200M, and a Tait TP9900.
Any help is greatly appreciated. Thank you.
KevinC
The big K
Super Moderator
Home
Get a parts donor MX radio off ebay and extract the connector from it. As I recall it is a separate part that fits in the frame and is sealed with a small o-ring.
Or a STX. And yes, it’s a separate part that you can pop out of the case/frame. I may even have a junker STX I can salvage one from.
cs361
Libby, MT
That would be great. I would buy it from you if you'd be willing to do that and have one lying around.
RFI-EMI-GUY
When you get a donor female MX or STX connector, chances are there is gooey rubber in the center where the speaker/mike switch is located. Just pry the goo out and clean up with alcohol.
