My 396
midnightcaller
Lake Stevens
What happen to some of my system's type?
I was going to set up a system and went to new system then select type and all I have is conventional,MOT,EDCS,LT I seem to lost all of the others I can go through the software
Butel and find it is ok. Do i have to do a reset? or is their some way I can get the other systems back with out doing a reset?
DaveIN
Founders Curmudgen
West Michigan
Did you back up your systems before you made changes? If so you should be able to restore them to the last settings you had.
UPMan
In Memoriam
Arlington, TX
Those 4 are your only options at the top level. Once you select a main type, any "flavors" of the type you chose will then be presented.
midnightcaller
Lake Stevens
Yep thats it I don't know what I was thinking forget the above post my brain stopped working for a few hours last night
