My First APX-6500
Hectomilan
California
Just purchased my very first APX series APX6500, I'm coming from the MotoTrbo line. I got so much to learn. I keep hearing TAgs , flash code , depot ASK protected, Encryption types ,Tuning and other things but I’m curious. And have many questions. Hopefully 🤞 I can get some help here.
First thing first what is tuning and why is it important to send your radio in for tuning ?
Thanks in advance.
As radios age, their alignment drifts. They can start to wander off frequency, deviation levels can change, filter settings, etc. To keep the radio running 'factory new' and to make sure it's operating within the specifications of the FCC license, they periodically need to be realigned.
I usually do our radios every year or two if possible. Most of them check out fine, but realigning an older radio can really perk them up.
Hectomilan
California
Makes sense. I’m guessing you need a special computer to do this.
Thanks for the explanation.
Now I how do you know if the radio has been tampered with a Depot Tool ?
You need a service monitor. A new one will start in the $30K range, and then go up from there. Mine, with current options, is pushing about $45K right now.
Much easier/less expensive to find a shop that has a modern service monitor and will tune it for you. Probably cost $100.
Hectomilan
California
can I become a customer of yours? Awesome thanks bud always appreciate your help here and in the Kenwood side. Do you anything on the flash port and how you know if it’s Been done by dealer or illegally ?
I don't dabble in such things, but there are those on here that can provide advice.
KevinC
The big K
Super Moderator
1 point
As a note, the APX series reference oscillator will pretty much age all it's going to age in the first 18 months. So after an initial alignment another alignment is absolutely necessary around that time.
