rixdafix
- Joined
- Nov 5, 2022
- Messages
- 17
Hello from St Louis, MO.
I've been an on again off again CB enthusiast for the last 45 years. I always just toyed around with stock AM mobile rigs. A couple of weeks ago I scored my first sideband unit, a Gemtronics GTX-77 in really nice condition. The radio appears to have never been tinkered with and I intend on keeping it absolutely stock. I've got it connected to a four foot firestik mounted on the fender of my Cherokee. SWR is excellent across the band. With skip ramping up, I've heard very good audio from some very distant stations. I call CQ from time to time not expecting any response but the other morning I got a call back from a local about 20 miles away. While this is certainly no DX contact, it confirmed that the SSB function of the radio is at least "working" and hey, it was my first sideband contact ever!
I am so completely addicted now.
I really enjoy field operations as I camp and overland quite a bit and expedient antennas interest me very much. I found plans for a quarter wave ground plane antenna and got all the bits together to make it happen. I'm using 12awg thhn stranded wire, 103" radiator, 116" radials (four) all soldered to a panel mount SO-239. I'm using 1/2 x 3/4" pine trim boards to create two spreader bars 165" long arranged in a cross with the radials anchored at the ends which should get the radials pretty close to 43 degrees. I'm going to use one rope to lift the spreader bar and another to lift the wire as I don't want to stress the SO-239 insulator or center pin solder joint too much. From what I've researched, I'll want the bottom of the ground radials hanging about 8 to 9 feet off the ground or higher than about 54 feet, but not in between, for optimal performance. I was going to test it today but we have 50 mph wind gusts forecast so yeah uh no. I'll post a couple of photos once I do get it deployed.
Anyway, I just wanted to introduce myself, share my experience, vintage equipment score, and first ever SSB contact!
561 St Louis clear...
