scloyd
Thanks Mike for the response.Well there's good news and bad news. Let's get the bad out of the way first. Depending very much on your local environment (do you have AM, FM or TV stations nearby, for example) the longer length may be enough to overload the radio. Too much RF is not something portables in this class are very happy with. You will likely be fooling around with the RF Gain control and switch to see what works best. If you start hearing distorted AM stations- or stations repeating in places where they don't belong - that's overloading. A better quality radio would laugh at it, but portables are simply not designed to handle this.
The good news? The length will make the antenna perform better going lower in frequency. This will make hearing pirates in the 4000-4200 khz and 5100-5200 khz area easier, assuming thunderstorms and the higher summertime absorption on these frequencies doesn't interfere. There are also a number - not nearly as many as there was, say, 20 years ago- tropical band broadcasters that the higher length will make a bit more possible to hear.
As my old physics professor once told me, Nature doesn't give without taking....Mike
I live in a small rural town (pop. 7500) about 60 miles west of Chicago. Our town has a community FM station (100 watts) at the high school which is about 2 mikes from my home.
The bad news doesn't sound so bad considering the small investment. I will leave the 50' antenna up while putting up the 85' antenna and see how it goes. If it doesn't work out, I either go back to the 50' antenna or buy a better radio. I'm into this hobby for only a couple of months and would like to put off purchasing a better radio so soon.
The good news sounds pretty good. I wouldn't mind picking up some pirate radio.
I thought about maybe some sort of antenna attached to the chimney and installing a two way switch. Who knows? I love doing all the research online - this forum, web sites...
Thanks again Mike.
