My G5 time is off by 2 minutes when they say like 13:23 instead of 13:25
ptr1959w
Vero Beach, Florida
Hi there, My G5 timing is off by 2 minutes like when they mention the time 13:23 instead of 13:25. Is there anyway that I can correct this? Any help is greatly appreciated. TIA
JD21960
ILL-annoyed
Yes, you press the bottom right hand button and select ** Function Settings and scroll to find time-date and change it there. THIS is common when you change something hooked up to a computer, save the PPS and then see the PC might have had the wrong time or a mismatch.
picscan
CA
I have an old laptop that I use just for the pager because I use a MacBook for everything else, the cmos battery is dead I guess. I always forget to reset it when programming the G5, sometimes it's a couple weeks off.
