My gre scanner will not shut off
crca
Coldenham NY
I was doing my updates,now my scanner will not shut off,please HELP Sorry it's the 800
IowaGuy1603
Jones County Iowa
Try pulling the batteries AFTER you pull the plug.............let the scanner set for a few minutes before you put the batteries back in.
THEN turn on the radio but don't plug it into a power source.
I found that if I pulled the plug (sometimes) without turning the scanner off ---it sometimes wouldn't shut off....... doing the above works for me
AZScanner
Somewhere in this room. Right now, you're very col
That sounds like a great feature to me! I used to run a feed and had a big problem with other members of my household turning the scanner OFF while I was at work, resulting in many hours of completely dead air being broadcasted on my scanner feed. It would have been nice to have this particular problem back then! :D
-AZ
IowaGuy1603
Jones County Iowa
-AZ
Yea.........when mine does that it just shows a blank screen................no scan
mancow
N.E. Kansas
Does it say anything on the display? It sounds like your update was corrupted. I would try reformatting and reconfiguring the card through the software then download everything to it again.
