My home brew gmrs slim Jim antenna
Thetoulman
Just wanted to show off. It's mounted in my attic. It has a 1.2:1 swr across the gmrs band, and around 2.0:1 on the upper end of 70cm band. Seems to work better than the simple ground plane it replaced.
ipfd320
Banned
W.Babylon N.Y. 11704
Thats a Nice Piece.....Can you put up the Specs and Measurements of all the Pieces Used....id like to build 1 of those
Rt169Radio
CT
Interesting,I take that you transmit with it?
Thetoulman
I do transmit with it, with very good results.
As far as measurements go, this is what I used.
http://www.m0ukd.com/Calculators/Slim_Jim/
I used 465 as the frequency (median between simplex and repeater inputs).
It's all type M copper pipe and standard elbows.
If I were to do it over I would use the same measurements but instead of measuring center to center on the copper pipe, I would measure the distances between the closest edges of the pipes. I found the feedpoint measurement from the calculator to be way off from acceptable swr; this could be from the center to center measurements, or the de-tuning of the antenna by adjacent metal in my attic.
Scuffing up the pipe with sandpaper helped make a better connection at the feed points under the hose clamps.
Thetoulman
One other thing of note on this project:
When this antenna is fed with rg-58 coax ~50 feet the distant gmrs repeater I built the antenna for is unreachable. With lmr-400 the same repeater reads s3-s5. So if you are looking for a high performance antenna system, don't skimp on the coax.
KD0WFZ
Feed line
The method you used for your feed line, can that in turn be used on cactus style j-pole?
dksac2
Idaho
You also need a balun with a J pole, they radiate off the coax like crazy, and yes, do use LMR-400.
John KF7VXA
