Figured since everyone else was doing it I would post a couple pics since I finally got around to cleaning the place a bit.
The plate is the antenna coax plate I made to finally hide all the cables. They were running down the corner of the wall but I decided to finally run them inside the wall. What a nightmare that was. I found out there is a 2x4 running diagonally in the wall. :evil: That's why the plate is above the desk line and not hidden below it. But, it's kind of easier to use that way. In the wall is six runs of Andrew LDF1-50, a run of LMR400, a run of 58 for HF and a piece of RG59 for the scantenna. The jack is for antenna mounted preamps and the phono plug is the rotator control cable. There's still a lot of work to do as far as wire hiding and power supply and speaker management.
