My one scanner and weather radio shack... suggestions anyone?
epdexplorer
Ok, I figured that even I have one scanner, you guys can help in giving me scanner suggestions and even setup suggestions.
ok, My scanner:
Uniden BC92XLT, got it at my local Farm and Fleet store, it was a experiment and it turned me to loving scanning! The Attenna is a Radio Shack Telescoping attenna, which is nice, it is better than the stock, but it depends...
(sorry, don't know what happened...)
Weather Radio:
Since I'm a spotter, of course I have to have a radio. My scanner does not have SAME on it, but I either hear it via Ham Radio or from this radio.
your scanner/setup suggestions are welcome!
chrismol1
Nice antenna on the scanner! looks huge on that scanner!
Depending on the way you are, these might be the last pics that are simple and clean, if you know what I mean, in the future you get more scanners..lol
epdexplorer
I know, it works that is what counts, and there is a little more to that attenna that is not in the pic!!! I know what you mean... and cords are a mess already there.....
scannersnstuff
nice,easy scanner to program and use.everybody's got to start somewhere.save up your money = new toy's.
kellykeeton
Oak Harbor, Wa
put up a map of your county, makes you look official
if you want suggestions, look at getting a antenna for external ..if 150 is what your listening to primary get a tuned antenna outdoors or put a wire to adapt the scanner take the stress off the radio BNC to keep it happy for years to come.
CanesFan95
Was Homeboys-Scanna
Banned
FL
I would start off by getting a tripod for the camera.
mkh
Rutherfordton NC
Nice start.
You will get better reception if you shorten that antenna.
Your scanner shows a frequency of 158.239 and for that you frequency range (138 - 174 MHz) only the top 4 sections should be extended.
epdexplorer
Nice start.
158.235 actually..... thanks for all the comments/suggestions!
mkh
Rutherfordton NC
If you don't have the instructions -
25 - 136 MHz - Extend all Nine Sections
138 - 174 MHz - Extend only the top four sections
220 - 1296 MHz - Xxtend only 1 to 3 lower sections
epdexplorer
i have them, but it seems to work fine the way i have it, but i'll try the what the instructions say sometime... Thanks mkh
chrismol1
deso it say that in the manual? i thought VHF was 19''
blueangel-eric
Emporia, KS
I find that the coil is activated when the bottom of the top sections is pulled out. I use mine as a dual band by using the top four and one or two of the bottom pulled out. The bottom sections pulled out or not makes no difference on VHF that i can tell. But pulling all 5 sections of the top cuts off the VHF-HI performance and sets it for VHF-lo. I've used that antenna since the 90's untill a few years back after getting flexible whip antennas.
