my Pro97 display is stratched need replacement
blueangel-eric
Emporia, KS
I dropped my pro97 scanner in the driveway on rocks and now the display is scratched. Radio Shack said they can't order me a replacement part so i would have to spend about $70 total to have them work on it. and the part itself would be $50. this is alot of bull. i can call yeasu or kenwood and order parts for my ham radios so why can't i get a part for my scanner?
i'm disgusted and the radio was new last february. i don't even know where to get a protective case for it. last i new radio shack don't even sell those.
KE5BCP
Analog Man
Lewisville, Texas
blueangel-eric said:
the local store over the phone.
Call 1-800-THE-SHAC. You'll have a better shot of getting it from the number than in store (some exceptions are out there, of course).
RayK
Bradenton,fl
Hi, if your looking for a case for the pro-97 , I purchased one from scannermaster ,worth the momey ,Ray
pro92b
Mutated Member
12430633 CASE ASSY FRONT $19.29 In Stock NON REPAIRABLE
The info was posted a while ago so call the 800 number to check price and stock. It probably has the non-repairable entry because the speaker is glued in the front case and is not easily removable. You might have to solder wires to the new speaker when you replace the front case assembly.
blueangel-eric
Emporia, KS
scanjunkie said:
There have been several posts on here about how to repair scratched dispalys...check them out.
so i read months ago. i did some searching for it but found all the wrong results. i don't remember when i read them.
scanjunkie
Montgomery County, PA
I couldn't remember when either...nor could I find any good results. Maybe some kind souls will re-post some of the methods they have found. Good luck!!
davidd2957
Suffolk County N.Y.
Scratched Display
Hey Blueangel-eric...How bad is the display scratched? Are the scratches superficial or are the scratches deep and pitted?
David D.
CommRX
Eastern NC
Brasso works well.
blueangel-eric
Emporia, KS
David D.
some bad enough i can feel them with my finger nail a little bit. so i guess some are deep and pitted. many are superficial from everyday use.
jim293
Idaho Falls Idaho
Brasso is a polish. You can get it at the hardware store. Try it. It may work I have heard of people polishing out there scratches with it. Worth a try.
1979lee
bakersfield, california
ok , i kown this is quite an ole thred, but, iam in need of a new case for my old pro97
does anyone know if there still availble?
i found this parts list on another scanner site
thanks lee
"available RSU parts"
11318532 DIODE 1N4002 RECT 600V.1A SI $.29 In Stock
10514404 XSTR 2SC4226(R24) SI NPN $2.87 In Stock
11449626 XSTR 2SC4116 SI LO PWR AMP NPN $2.49 In Stock
11840212 XSTR SI DIGITAL PNP/NPN $2.49 In Stock
10539476 ANTENNA,RUBBER 15.8CM $10.99 In Stock
10570166 FILTER,CERAMIC 455KHZ $7.18 In Stock
12357562 CRYSTAL 12.75MHZ $9.49 In Stock
12357570 CRYSTAL 20.945MHZ $8.13 In Stock
12357687 CRYSTAL 12.288MHZ $11.11 In Stock
12430674 COVER BATTERY $3.29 In Stock
12430658 HOLDER ASSY BTRY RECHRG $4.69 In Stock
12430666 HOLDER ASSY BATTERY $4.49 In Stock
12418273 CLIP BELT $3.29 In Stock
12418349 REFLECTOR LCD $2.49 In Stock
12430682 KEYTOP $5.99 In Stock
10720209 JACK,ANTENNA $8.29 In Stock
11840063 JACK,EARPHONE $2.87 In Stock
12228714 JACK POWER $2.49 In Stock
12430690 KNOB SQUELCH $2.49 Not In Stock
12430708 KNOB VOLUME $2.49 Not In Stock
12430617 LED FY1112H-1-TR(D OR E) $2.49 In Stock
12430716 LCD $23.49 In Stock
12430724 MANUAL USERS 20-527 $4.99 In Stock
10881886 IC,NJM2904M LINEAR 8 PIN (S) $2.49 In Stock
10894061 IC,74HC4066F 14 PIN $4.84 In Stock
12100327 IC TK11819M SO6S SMT $4.87 In Stock
12106522 IC KA3361BD SO16S $5.99 In Stock
12357596 IC HD74AC164T SMT $4.62 In Stock
12410775 IC SMT TMP93PS44F $54.99 In Stock
12430583 IC SMT MB15F07SLPFV1-G-BND $16.49 In Stock
12430609 IC SMT EEPROM HN58X24512FPI $17.99 In Stock
12429163 POT VOLUME 50K OHM $15.89 Not In Stock SQUELCH 10K OHM
11717485 SPEAKER 8-OHM 500MW $11.89 In Stock
12430591 PCB ASSY LOGIC $81.29 In Stock
12430625 PCB ASSY RF $27.99 In Stock CONSISTS OF: PCB ASSY RF CHASSIS TOP ESCUTCHEON TOP JACK ANTENNA PM 2X4 NI OR BLK SCREW
12430641 CASE ASSY REAR $12.69 In Stock NON REPAIRABLE
glide
Lenoir City,TN
Too Late Now
Protective cases work well before the fact.They won't do much good now
trunker0205
Rhode Island
I use it all the time and it works quite well...:)
WayneH
Forums Veteran
Super Moderator
Your master site
Moved to the RadioShack forum. Please take a moment to read over all forum descriptions before starting a new thread next time. Thanks.
