OK2BCK
Very pleased to see this!
Thanks for sharing.
Jan
Thanks for sharing.
Jan
Dang. You should get your electrical engineering degree and then you'll be all that.
Trak Systems GPS clock, used as a timebase reference for all other equipment,
ensuring that all time-based signals and measurements are highly accurate.
HP 8828a 1.3 GHz frequency counter
HP 8901B modulation analyzer, includes power meter, frequency meter, metering
of AM, FM, and phase modulation signals.
Tektronixt 2565B 400 MHz 4 channel oscilloscope, one of the best scopes ever
made. It's an analog scope under digital control and I never liked digital
scopes, not even the newest ones.
Rohde & Schwarz SMY 02 signal generator, 50 KHz to 2.08 GHz. AM, FM, and phase
modulation, works down to -140 dBM.
HP 3325 audio/function sweep generator, has a variety of uses including
analyzing the performance of a modulator circuit with varying waveforms.
RDL multi-tone generator, intended for GSM cellular use. It generates up to
16 different signals, with up to 8 being generated at the same time,
8 being in the 800 MHz band and 8 being in the 1900 MHz band. Though I
have no use for the 1900 MHz band capability, I use the capacity to generate
up to 8 800 MHz range signals for evaluating intermodulation rejection and
adjacent channel rejection performance on recently repaired radios in the
800/900 MHz band. It's a pretty esoteric piece of gear for a radio shop
to have, but I got it for almost nothing, and having the capability to test
intermod and adjacent channel performance is VERY nice and can be extremely
profitable. My service rate when using THIS gear is 10x my usual service rate.
Patch bay. The back side connections are routed to other pieces of gear to
allow me to use their back panel connections without having to pull the rack
out and crawl inside the back.
HP 3566A dynamic signal analyzer, a spectrum analyzer for the audio frequency
range. I'm not using it yet because it has to be connected to a PC via a
GPIB interface card and I just haven't gotten around to setting it all up yet.
An HP microwave signal/sweep generator, I forget the model number. I have
two of them, covering from 2 GHz to 14 GHz in total. They are useful for
testing some wireless networking equipment such as antennas and signal
strength meters.
Another RDL signal generator, I got it for almost nothing and haven't used it
for some time because it needs a new fan and the other RDL generator is
a lot better. I should ebay it.
I'm REALLY glad that I didn't have to buy all this equipment at new prices,
because it all probably cost the original companies that first bought it a total
of maybe 150,000 dollars.
Several pieces of equipment in this rack were retired from GE's Lynchburg facility,
as a matter of fact. The GPS clock, the modulation analyzer, the frequency counter,
those for sure and I think the 3325A function generator came from there as well.
Elroy
