My Shack w/Max
N9JIG
Sheriff
Moderator
Far NW Valley
Each device in shacks like Ted's or mine usually have very specific functions. In my case I currenly have 10 scanners (3 BC15's, 3 BC780's. 2 BC785's, a Pro2096 and a BC996), each with specific functions. For instance, my BC15's are dedicated Fire Tone Out Receivers, the 785's are used as "GoTo" radios for Trunker and Pro96Com, the 996 is used to monitor a local APCO25 trunked system and for CloseCall work, )ne of the 780's and the 2096 are used for Trunker/Pro96Com and the other 2 780's are used for local police, fire, rail and aircraft use. I also have an R8500 used mostly for searching, a dual band ham rig and a pair of Moto mobiles used for GMRS and other stuff to talk on.
Most scanner nuts that use multiple radios like this that I know usually have very defined purposes for each radio, and match the radio up to it's strength. One of my 780's is particularily sensitive on VHF-High so I tend to use it mostly for fire and railroad, another 780 works real well on 800 and thus is dedicated as a Trunker data receiver.
Many of us also use different computer logging programs, so often do not actually listen to the radios much of the time, but rather collect data via programs such as Trunker and Pro96Com.
I also use multpile computers. My main computer is a PowerMac with dual monitors, and I also have a P4 loaded with RAM and a couple large hard drives that I use to record audio files for later decoding (mostly for fire tones). I use an older DOS machine for Trunker, and when not in use elsewhere I have a couple laptops that are used for special purpose stuff at home. These laptops however are often in use at work or in the field, so are not always available at home.
I count myself lucky as to being able to afford to obtain radios and computers to dedicate to specific tasks like that. Each of the radios in my shack has a purpose, and while may not be so tasked all the time, it doesn't just collect dust. I also justify some of the expense for work purposes, both in my career field and consulting endeavors, but for the most part it is for hobby purposes. I will admit however to cleaning up the joint before taking pictures for this forum, my shack is not usually as neat as my pictures tend to show.
platinumrx8
ok, that makes more sense Rich.. see, before I purchased my first scanner (pro-528), I looked at many different scanners on the market.. It was very hard to decide on which to get, but I knew I had to get at least the triple trunking and wanted something portable with speaker built in.. The Pro-528 seemed to be the best bang for the buck plus it is rebandable.. What I didn't realize is that even though many radios carry some of the same features, their performance in certain areas differ from reviewing what you said in your post.
I currently only listen to the 850-870 (trunking police, fire, EMS, etc) and 900-935 (pick up local calls, do it for personal amusement , lol) ranges at this time..
I think for now, I'm set.. maybe in time, I'll purchase more stuff.
by the way, is it possible to use a program to record things while your away, but only things that come up with a tone, not just dead air and waste space?
trooperdude
SFO Bay Area and Las Vegas NV
platinumrx8 said:
just curious, but why would anyone need so many scanners like that? how could you possibly listen to it all?
Some of us are former public safety dispatchers.
It's not a matter of "need". It's a hobby.
Nobody "needs" a P51 mustang aircraft at >$1 million either. :D
It was pretty common in an urban dispatch center to have at least 5 channels up in the background with the main channel in your ear, and keep track of almost everything that was going on, while typing in the computer at the same time.
I guess it's a life-long skill.
:D
MWillyG
Southington, CT
Your Pics...
I concur with previous posts. Veerrry nice!
As my teenage daughter would say, "Whoa, that's awesome!"
pathalogical said:
Very nice and neat. Looks like your shelves are sagging a bit.
Hey... your shelves would be sagging too, if they were holding all that fine electronic equipment! ;-)
One question: What is the antenna that is arranged horizontally toward the bottom of the mast?
Thanks for posting your pics.
chgomonitor
Silent Key
Chicago
Yagi
It is a commercial 12 (?) element high gain yagi for 800 Mhz. I bought it used at an estate sale - one of Jeff Zeman's antennas for those who knew him, great dude. Sorry I don't know the brand or model, Jeff bought a lot of stuff as generic surplus from wholesalers.
It does well on all the 800 Mhz systems to the south of me but it's primary intended listening target is a low power city of Chicago 800 trunked system at O'Hare airport.
It is fed with Times Microwave LMR-400 low loss cable. It is normally connected to a Uniden 245xlt, of all things, LOL. Max says; "Hey". Happy Scanning! - Ted and the cats
N9JIG
Sheriff
Moderator
Far NW Valley
publicsafetyvehicles said:
Just a guess, but wouldn't that feline's tail enhance communications reception while monitoring a major CAT-astrophe?
Ugh!!!!!!!!!
Quickcall
Director of Saltiness
Central New York
kjfswkr said:
Nice setup. Cat has to go.
Kevin
I dont know, my cat has proven himself worthy in my shack back when I had a mouse running around.
Excelent setup!
w8jjr
Lincoln MI
:D
Yes it is a skill. Having been communication tech in Navy and dispatching for years you learn to tune out the noise and train your ears for key words and emotion in the voice. It still gives my wife a headache LOL :)
daysand
Houston Texas
Man Alive !!!!
I sure would like to have a Splitten Image of that Fantastic Radio and Antenna setup , in my world. Yep !! Sure would.
Also !!
You have a "Clean" and Great Looking Shack, with a Pretty Cat @ that.
