I'm just finishing up with a third radio in my 23 Wrangler Rubi 2 Dr. to complement my Motorola XTL5000 High Powered Remote Mount UHF radio and my Cobra 25 LTD Classic AM/FM CB Radio. My third radio is a Motorola XTL2500 Remote Mount 840 Channel VHF radio. I 'm going to use a Laird TE Connectivity B1442 Base Load Non-Groundplane antenna hanging on the driver's side at the cowl with a Rugged Radio mount.
I have the radio installed and the electrical connected however, I am waiting on a Powerwerx Anderson Power Pole Distribution Block. I had to remove my CB, Garmin Navigation Systems from the existing distribution block in order to power the newly installed radio.
Essentially, all I have left to do, is finished up on the antenna mount grounding system, running the NMO antenna mount cable, install the Mini UHF connector on the cable, and tune the antenna.
I intend to do that tomorrow. I called it a day at 3PM Arizona time. I've been out in the garage since 8AM and it was 113 degrees.
Then, I will need to program the radio.
