- Joined
- Aug 19, 2014
- Messages
- 77
not sure if this is the right forum for this, but i thought i'd pass this along because i hadn't seen anyone mention this before.
i'm trying to feed 4 scanners from my roof Tram discone. the feed comes in to my attic and splits off via multiple SMA pigtails to an SDRDuo, down a 20ft 50ohm cable my old Pro197, then on to 75ohm cable to an old MR8100, and an RTLSDR stick... reception has been... meh. SMA splitters and a lot of adapters, and even a fork from a 50ohm split SMA cable to an old piece of 75ohm coax to the basement... the guys who tested me for my Amateur General license would be offended.
i needed to clean things up, so after some research i ordered a Stridsberg multicoupler... but it hasn't shown up and i've had no reply to my email, and some research here caused me to realize that while the company is apparently still producing amazing products, they are going through some restructuring and that's causing shipping delays and communications issues.
so i'm thinking about other options in the short term... searching online... and the guy who runs Frugal Radio mentioned how he used a CATV amp... and then i started to think about the Channel Master Titan 2 that I had in my attic that i had to remove from my OTA TV feed because it was overpowering my TVs (I'm too close to local TV towers to use it).
so i tried it... pl259 to type F into the Titan 2 with a 75ohm jumper cable... then a 75ohm jumper into the SMA pigtail splitters - still a mess!
but... it seems to have worked.
it's a mess, but i'm hearing way more traffic from my airport instantly, picking up VHF traffic from dispatchers louder and clearer, i can't say it's 100% effective yet and i will definitely be replacing all the splitters etc when the multicoupler arrives, but i'm a little surprised this idea isn't more common. the 54 - 700 MHz range is definitely going to be an issue with local trunked systems, but i know channel master has made preamps that go to 1000Mhz - and they aren't expensive when compared to systems like Stridsberg.
how did i miss this??
does anyone else have inexpensive hacks like this that i should be using?
love to hear any thoughts, thanks.
richard
richard
